WG 19K4906 Needs Repair / Tube Swap - Austin, TX
cmoses
Texas
Recently picked up a cocktail cabinet that has a Wells Gardner 19K4906 arcade monitor in it. I got a great deal on it, but didn't have any idea what the condition of it was. Once I got it home and was able to get it to start up I found that the monitor has a vertical collapse issue. I do know that it also has some burn in on the screen.
So I am looking someone locally that would be able to repair the vertical collapse, also do a cap kit and maybe a tube swap. Or if someone has something that I can swap out and exchange with my monitor that would also be a consideration.
I found a page while during some searches that said the Sanyo 19" 91C530 is a good TV for doing a tube swap. I started looking around for one and have emailed a couple of ads I saw on the local Craigslist. I did run across one ad that posted a model number but the unit is a combo TV/VCR so I am not sure about it. Does anyone know what tube is used in a Sanyo 19TVR95? Looking to see if it might be the 19VMFP22 tube that I need.
If you are local and can help me out let me know. I am not sure if fixing the monitor I have is worth it with the burn in it has. Never really dealt with this issue before. Any advice would be appreciated.
your best bet is to send your chassis out for repair if you do not want to tackle the problem on your own.
me and others on the fourm can fix your chassis.
someone local may have a different monitor to swap/sell you.
after you get your chassis repaired you can continue to look for a good tube swap replacement.
they're are many different TV's out there that will swap tubes not just that one make and model.
if you want me to repair your chassis, PM me.
Peace
Buffett
