Auric
Was working good, then yours truly was adjusting the picture via the standard pots on the main board and I felt a very light (VERY light) shock from the board and the tube went dark. I've checked the voltage going to the monitor and all fuses on the board and the cabinet itself and they check out OK. The boards on the monitor look OK, as nothing appears blown out or burnt.
Anything I should check specifically? Or is this a recap and try again moment?
