Wells K7193: No sync after cap kit
GuidoTorpedo
Maryland
Ok, what did I screw up? It worked before I capped it, just had a crummy picture. I can tell the picture will look nice once I can get it to sync, but I can't get it to sync after testing the monitor in 2 different cabs. What did I do?
-Mike
Well, the obvious question is - are you testing it in the cab it worked in? If not, then the other cabs might have the sync wired differently.
Did you reflow the solder on the video input pins? Go over all your caps again and make sure they are in properly...
