Wells Gardner monitor problem
adamu
Dublin, Ireland
Hi, looking for some help with my monitor. When I turn on the cab no picture appears on the screen, the monitor doesn't appear to be working atal. The gamebaord seems to boot up though, as I can hear music through the speakers.
I have posted pics if this helps.
Monitor is a Wells Gardner 25K2193.
Yeah, this is a fairly easy chassis to work on (if you know your way around monitors). Is the fuse blown? Start with the cap kit and look for cold solder. The see what you get. Might as well check the HOT while you're in there (black lead on center leg and red lead on outer legs). Once you've capped it, if it still doesn't work, check the B+ reading and report back...
