john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Jul 31, 2011 #1 Just did a capkit and the image only improved a little. What causes the image to look so bad? Thanks!
paul400 Well-known member VAPS Joined Nov 8, 2010 Messages 2,416 Reaction score 219 Location Hixson, Tennessee Jul 31, 2011 #2 your tube might be weak and needs a rejuvination. what happens if you turn the brightness up?
modessitt Volunteer: Encyclopedia Submission Moderator VAPS Joined Mar 22, 2007 Messages 33,414 Reaction score 325 Location Austin, Texas Jul 31, 2011 #3 Which brightness are you turning up? The one on the flyback or the one on the chassis? What happens if you turn the colors up? Might need to rejuv...
OP OP john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Jul 31, 2011 #4 I'm not seeing a brightness pot. I tried the flyback screen knob but it doesn't do the right kind of brightness. Previous owner did mess with the black level pot so that is probably in need of adjustment.
paul400 Well-known member VAPS Joined Nov 8, 2010 Messages 2,416 Reaction score 219 Location Hixson, Tennessee Aug 1, 2011 #5 The brightness pot is 1 of the 2 above the line of 4 pots. If that made sense
OP OP john2654 Well-known member Donor 3 years: 2011, 2020, 2024 VAPS Joined Mar 30, 2010 Messages 6,426 Reaction score 1,272 Location Rhinelander, Wisconsin Aug 1, 2011 #6 I already tried tweaking the black level (aka brightness). Not much help, still washed out. May need to finally buy a rejuvenator. front row pots left to right: horiz centering (shift), vert size, vert hold, vert damp, (blue colored) vert pos. back row 2 pots left to right: horiz hold, blk level
