Wells Gardner D9200 power cable
SilentGunstar
Ohio
Hello all. I have what I believe is a Wells Gardner D9200 chassis / monitor setup. The board has PD279200 printed on it. I have included photos that will hopefully confirm my identification.
Anyway, I need a replacement power cable for this - when I bought it, it just didn't come with one. It looks to use the 3-prong style that I've seen at a few stores online, but those don't seem to match my particular model number. A few posts have mentioned that I may need some kind of adapter between the power cable and the wall, but a lot of this info has gone over my head.
I'd appreciate any advice on where to snag this power cable. Unfortunately I don't possess the skills to make one on my own, so I'm looking for a prefabricated option.
Sorry, I really don't know any of the technical aspects of what I'm dealing with here.
JST is the connector type?
pinout
Just use this pinout and solder to the chassis. You don't need a fancy wire. Just be sure to wire it correctly. Apply some silicon or hot glue and add your own molex connector if you want.
JST is the manufacturer.
VHR-5N is the part number for the plastic housing (the white part).
SVH-21T-P1.1 is for the metal pins the wires crimp to that are inserted into the housing.
You will need a pair of crimpers for those pins (and NOT the all in one automotive crimpers). A needle nose pliers will work poorly at best.
