Wells Gardner 25k5108 image problem
phil13955
Hi
I have a whole 25k5108 that has a problem I have not seen before and can't accurately describe it.
It seems to have my tpg image 3 or 4 times in one screen horizontally.
My b+ is at 117v and test points 103-106 and 200-205 are pretty much close to what the manual calls for.
The person that I bought this from messed with the convergence rings and I don't know if this is related to that.
Any help would be greatly appreciated
Phil
Here's some pictures
you mean U5000?
you're probably in the wrong resolution. you change it with the power off.
you mean U5000?
Sorry it took me so long to get back to you.
It's set for 25k. Should it be set for 15k?
I haven't learned when to switch it from one to another.
yeah if your TPG is in standard res mode, it will not work right in medium res mode on the monitor.
you can switch the plug to 15K with the game/monitor off, then turn it back on and try the TPG again. otherwise your TPG should have a resolution slide switch that says like STD / MED, you can switch it to MED and it should work with 25K mode.
Finally got back to the monitor.
I tried switching to 15k and tpg set to 15k no luck and switched back to 25k and tpg switched to med res and the same.
I am starting to wonder if the problem is something in the horizontal section
Could this be a possibility
Thanks for taking time out for me
