FS Parts: Wells gardner 19k4901 monitor chassis
tddlny
Plainfield, Indiana
This is a Wells gardner 19K4901 monitor chassis out of a 1982 poker game. The monitor had very severe screen burn so I decided to just part it out.The machine had no game boards or power supply in it. I tested the monitor before taking the chassis out of it by plugging into a power supply. The rear of the tube actually glowed nice and bright orange. Also when I discharged the monitor it popped like it should. This tells me that the flyback is probably good. I had no boards to plug into this game so I could not test for colors. When I unplugged it the monitor flashed like it should. It comes complete with the neck board and the yoke all intact with all the wiring. All boards solder joints to be intact. I have to sell this as is because of its age. This monitor was used in a lot of the old classic arcade games of the early 1980's. If you need an original part then this is your auction. If you need an original Wells Gardner monitor chassis then this is your auction. This chassis is VERY HARD TO FIND especially with the original yoke and neckboard. I will let it go for $40.00 shipped! United States only
