wells gardner 19" k7000 series question very easy. .
INOVERMYHEAD
Ohio
have a wg k7901 19" need to know what are the values and witch way do the neg leads face, toward the flyback or away from the flyback. for c4 c5 c6 . . . thanks for the help. . .
C4, C5, and C6 are polarized electrolytic caps? They're not on the cap kit list.
The cap should have a stripe with minus signs on it on one side, indicating that is is the negative leg. The board should have a + sign next to one leg, indicating which hole is the positive leg, or will have a spot near one hole indicating a negative leg...
well i replaced them anyway, and did not notice when i pulled the out which way they went, there is no markings on the board as to which way they go, thats wht i ask, toward flyback or away. .
If there were no markings, then you must be referring to the three bipolar caps on the chassis. You can't replace those with regular polarized caps...
ya, i see that now, kinda botched that one, so i threw old ones back in. .
