wells d9200 no OSD menu
LyonsArcade
Rock Hill, South Carolina
So I can actually adjust it blind, but I would really like to see what I'm adjusting, anyone ever have this issue?
I've tried a different Neckboard with same results, also swapped the IC on the board that people say will get corrupt
Figured it out, the CGA connector the solder was bad on the sync pin, which was confusing the monitor and the OSD won't display without a good image on the screen.
This I'm going to have to test soon once I get access to a D9200 I done work with.
Always hate it when the cause of an issue is in a place you least suspect it.
