Wells 4900 C313 cap
armi0024
Donor 2012
Minneapolis, Minnesota
Just got a cap rebuild kit from arcade shop...and it has a 47 @ 250 for C313, but the cap on the board was 100 @ 160. I'm thinking that I should stick to the 100 @ 160, any thoughts?
You would be wrong in your thinking. C313 calls for a 47uF 160v, and the 47uF 250v provided will work fine.
So either:
1) in the past someone swapped out that cap, and it was the wrong cap, or
2) you grabbed the wrong cap, or
3) it was wrong from the factory.
Ok, I would have agreed, but this thread says C313 is 100 at 160V
http://forums.arcade-museum.com/showthread.php?t=91824
and this manual says the same...
http://www.basementarcade.com/arcade/library/manuals/m/atariwg19k4914.pdf
I put the question out there because I know people have made modifications to the cap sets over time to get rid screen curl, etc. on some monitors...
The monitor seems to be working, I was tossing a 60 in 1 in and it has some curl on the left side of the screen, something that is not atypical for those boards from time to time as I have found....
The WG4800 (basically, the 13" version of a 4900) series uses a 47uf160V cap at C313.
The early version of the 4900 uses a 47uf160V cap at C313.
The later version of the 4900 uses a 100uf160V cap at C313
WELLS-GARDNER K4800 13"
1uf50V C315/C351 Both 105 Cap
2.2uf50V C303 105 Cap
3.3uf50V C308
10uf50V C310
10uf100V C702 105 Cap
10uf160V C311
22uf25V C366 105 Cap
22uf160V C506
47uf25V C352/C354 both 105 Cap
47uf160V C313/C507
330uf16V C301 105 Cap
470uf16V C205 105 Cap
560uf200V C505 B+ Filter Cap
1000uf16V C201 105 Cap
1000uf25V C701 105 Cap
Wells-Gardner K4906 Early Version 19"
1uf50V C315/C351 Both 105 Caps
2.2uf50V C303
3.3uf50V C308
4.7uf160V C311 105Low ESR Cap
10uf100V C310/C702 Both 105 Caps
22uf160V C506
47uf25V C352/C354
47uf160V C313/C507
330uf50V C301 105 Cap
WELLS-GARDNER K4900 19"
2.2uf50V C303/C308
4.7uf160V C311
22uf160V C506
47uf25V C352/C354
47uf160V C507
100uf160V C313
1uf50V 105 Cap Piggybacked to D306 negative to banded side
Edward
3.3uf50V C308
10uf50V C310
10uf160V C311
22uf160V C506
47uf160V C313/C507
2.2uf50V C303
3.3uf50V C308
22uf160V C506
47uf25V C352/C354
47uf160V C313/C507
2.2uf50V C303/C308
4.7uf160V C311
22uf160V C506
47uf25V C352/C354
47uf160V C507
100uf160V C313
Edward
So sorry to dig up this old thread -- but appears I have the early version as I have 3 changes with C308,C313 and C301 from the 4900 cap kit I got vs the earlier version
Do I need the original values or is this an upgrade to swap them to the 4900 values?
or is that a bad idea?
Was doing a cap kit on a 4900. I found a bunch of info, but no info from BoB. So I thought I would post what he sent back to me for people in the future.
Hello Mr. Roberts.
I have used a few of your 4900 cap kits in the past. I was doing a cap
kit on a 4900 I have. At location C313 you have a 100uf 160v for your kit.
I had a 47uf 160v in that location on my monitor. Is that the way they were
built? Also I noticed at c308 you replaced it with a 2.2uf 50v. The
cap. I had was a 3.3uf 50v. I know you have a bunch to do, but I thought I
would ask.
"The reason that the replacement sheet comes with the cap kit is to
straighten out all the errors over the years of service & take care of any
field upgrades. Always go by that sheet & disregard anything on the chassis."
