Weird Spy Hunter Hum (Coin Door Lights)
Anthony605
HOWELL, New Jersey
I just restored a Spy Hunter which came out super nice. Everything looks and plays great. The last part I installed was the coin door. Prior to installing the coin door, there was no hum coming from the speakers. Once I installed the coin door with lamps, there is a noticeable hum coming from the speakers. The hum goes away once I remove the coin door bulbs. The game is currently running an Arcadeshop power supply adapter with the heavy duty (silver) power supply. My other MCR games (Tapper, Kick, and Journey) run the same power supply setup and do not have any hum with the coin door bulbs installed. Is it the bulbs causing the hum? Anyone know of a solution? Last, does anyone make 12V wedge LED lamps that can be uses that are not bright as hell? Thank you!
