Weird Neo Geo Cab Issue
SSilver2k2
Florida
Lo all!
Not sure if this should go in the monitor forum or in here, so i'm erring on the side of general repair.
I finally found a new neo geo power supply for a totally untested neo geo machine I got for $50. I was able to rewire the power switch, and finally get it to turn on. I threw in an old SF2 board to test the jamma harness, and everything comes on, except the monitor is making weird images. I can see sf2, but it looks like its blinking on and off real fast and that theres a vertical hold issue as well. When I throw in the neo geo board, it comes up fine (though with a calendar error which is another issue altogether, luckily I have a spare neo geo board.)
Any thoughts? On my other neogeo cabinet, I can throw in any board in there and it plays fine.
(psssst.... the calendar error is easy to fix! check my repair logs...)
well, i've already replaced the battery, and I just got in new 32.7xx crystals in to replace the other crystal. If that doesn't work, I'm going to try to resurrect it with a UNIBIOS, or send it to you ;)
just a small bump...
any ideas why the monitor would roll with a sf2 but not with a neo geo board in it?
