MKtrill
i just installed this i think old old version of a k7000 chassis and monitor into my mk2 cabinet, the picture shows up, however it looks awful. first of all from my pictures you can see what appears to be a flat line at about an inch and a half off the bottom of the screen. it will not go away, ive adjusted all of the potentiometers on the chassis, and the hold seems to affect it a bit, once the screen has filled out completely, it just scrolls up and down and will not stop unless its put back into that nasty position. this chassis has no satalite board, all the adjusters on on the chassis itself. the flyback has the infamous white knobs, and there is some hard glue like substance on the focus knob on the flyback. also the screen seems to shake in the corners, and it looks almost turned at an angle a bit on the right, as if the tube itself isnt straight. could this be just a simple flyback install? is there a particular cap that once it goes bad makes it impossible to get rid of that flat line untill repaired? any help or advice would be much appreciated. i have included some pics of my problem at the bottem.
thank you
http://www.facebook.com/photo.php?fbid=1747582605746&set=a.1412766395550.2058172.1124224229
http://www.facebook.com/photo.php?fbid=1747583405766&set=a.1412766395550.2058172.1124224229
http://www.facebook.com/photo.php?fbid=1747589045907&set=a.1412766395550.2058172.1124224229
http://www.facebook.com/photo.php?fbid=1747587485868&set=a.1412766395550.2058172.1124224229
http://www.facebook.com/photo.php?fbid=1747585605821&set=a.1412766395550.2058172.1124224229
thank you
