DaveyPocket
I built a small arcade test rig with a 19" WG 4600. Works nice. The monitor is built for vertical orientation (The frame, that's all). Whenever I rotate the monitor on it's side, the colors on the left side of the screen have a weird green haze to them... Same with the corners. Is this some sort of convergence problem? It doesn't have this problem when vertically oriented. Is it my floor? Magnetic interference? Capacitors?
Thanks.
Thanks.
