monsterbaldy
I have a track and field, and the right most run button is having some odd behavior.
Here is what I know:
It never closes the circuit when it is not pressed (good).
When I hold it down sometimes it exhibits rapid fire behavior. I am testing this in the name select screen. SOMETIMES it just behaves normally and goes at the normal pace when held down.
All the other buttons seem ok.
Switch seems good... it is a leaf switch.
Wiring connectivity tested ok, I am slightly suspect of a Molex connector between the buttons and the board as it had some corrosion.
Could this be caused by a spotty connection of the positive wire? The ground I think is fine since the other buttons are working fine and have the ground daisy chained. It is the LAST button in the ground link though.
-ben
-ben
