Wei Ya plug and play?
willymotts
New York
I got the 826HR replacement chassis for my K7131. I hooked it up but am getting an inverted picture (mirror). I received no specs or part list or anything with this. Is there an easy way to fix this or do I have to go with the old "cut the yoke plug" remedy? I was really hoping this was going to be an easy job. Thanks.
I have changed the picture by switching the plugs at the yoke, not at the board.
I don't know if that will help, but thats what I have done.
There are two sets of yoke connectors on Wei-ya main boards. With the power off, simply unplug the yoke from the connector you have it in now and move it over to the alternate yoke connector pins located directly next to the ones you just unplugged.
One yoke connector gives a normal picture and the other one gives an inverted picture for cabinets that bounce the monitor image off of a mirror like Teerminator 2.
Yeah, Ken, I tried that but no luck. One is backwards only and one is backwards and upside down. So now I switch the horizontal yoke wires, right? Thanks.
Yeh, the connector set that just gives you a backwards image is the one to use.
The red & blue wires are the horizontal section of the yoke so reverse the position of the red & blue. Where the blue was should now be red and where the red was should now be blue.
