? Wei ya chassis info ?
What is this? and which one do I want or need to use? If you look at post #9 a pic of the manual shows a jumper for Video color or ITT. What is this? Thanks Long Hair
i have this tech' sheet in English :)
Chinglish
(N) "video color"
(W) "ITT"
English
"N/W" = Horz' width range adjust
(N) lower
(W) high
this jumper selects between 2 x capacitors to fine tune size....
above that jumper is the tube size selection jumper
Chinglish
N, W Hori Range
Englist = CRT size selection
in short it gives you a tube size range will suit eg 25/26 inch or 27/28 inch tube
you then use that other jumper to fine tune size adjustment ..
Actually, (N) = Narrower and (W) = wider.
Cheers.. well that is what i thought it would be..
but got my translation from a Chinese person at local markets, with not good English..
But if you look at the position of this jumper & what it does it makes sense as lower/higher
as this is fine trim of the CRT size capacitor set..
