Wei ya 826 collapse
BobsterD
New Mexico
I have a Wei Ya 826 that has verticle collapse, can't seem to find out any issues. Anyone have this problem before?
I would replace the El caps
And vertical ic at the same time
And confirm You have 24's at the vcc
Going to the ic. Or at the diode
In front of the ic is a good place to check
If you like before ordering any parts.
Do you have a part number for the vertical IC?
Location, Ic401. Use the number on it for a placement number.
And some heatsink paste. To replace the old paste, bad caps will make
The ic run hotter and shorten its life, because it's a high current component
Needs to keep cool, for best results restoring the vertical circuit.
Sometimes it with short and open the 24'v supply from flyback
Check it out
Sorry, I'm new to these chassis, can you tell me whereabouts IC401 is?
Ok, I *believe* the IC the screw pointing is correct. There's no markings indicating it though
The ic on the heatsink
With to much paste on it.
You could reuse it, if needed
It needs just a small amount
On the ic. La7840
That's a good number you came up with
And if you got 24's on the diode and if
You could measure the 3 watt resistor
That looks overheated.
You see which one I'm talking about
Lift one end and measure the ohms across
The resistor should replace it to.
All the color bands are missing it's been
Running to hot.
Because to much B+ or bad El caps
Check it out.
Update: recapped chassis and replaced vertical deflection ic, no help.
Never to late to confirm you have the your vertical Voltage
Mention a few times
It's not uncommon to kill the voltage to the ic when it fails.
Does the ic get warm at all.
Does That chassis have a service switch?
To set RGB tracking? It does open the vertical drive when setting
RGB adjustments.
Sorry, I need more handholding. How to do confirm vertical voltage.
There is a Physical switch on the bottom, near the center.
It's ok to switch when running, could be a sync polarity
If not that and no bad contacts or connection then Need Number on ic
Google that number
See data sheet. It will show the pin out and Vcc
Most common 25-27vs dc
Or probe the diode I talked in front of ic for the voltage
or any of the pins on the ic..
Does vertical heat sink get warm after a while or at all?
Anytime you have no vertical deflection you need to turn down the
Black level or screen pot, so not to burn a line on tube during troubleshooting
While testing voltage on ic. Or over 15 minutes
And when you think vertical is working then turn it up
And check, to much time with brightness up with cause burn
So I probed in front of pin 6 which should be fed by D401. I have 24v before the diode but not after so I pulled it but it passes the diode test.
I also pulled r336 and it reads open out of circuit so I think this is the culprit. The schematic says 1w 4.3 so I assume this is 4.3 ohm. I'll try to find a replacement.
So I replaced r336 and have +24v to pin 6 now. Still collapsed though. I'm starting to think this chassis is beyond help.
it's not a good design but can be a replacement
Chassis not one you depend on long term.
Measuring the yoke is always a option in some cases.
To fine a close chassis compatible to yoke and tube neck board
If you would like to find another chassis,
With the schematic we should be able to find a fix,
Hopefully you have the correct vertical ic
After a few minutes does the ic feel warm?
Now that it has voltage to it.
With the resistor open then the ic was shorted
So that should have fix your vertical collapse
Luk
Yeah, I may swap the original IC back if I get bored. This tube is also weak so I'm mostly working on it for experience and challenge. It's getting to they point where I have almost as much money in this as a new Wei-ya chassis so this may end up as a parts donor.
