Frax
Weak jets...want to replace the linkages, but how?
Going to order some parts when I get some money (grit teeth), the weak jet bumpers on my pinbot are bugging the crap out of me. How much of it is simply adjustment? The linkages seem to have a lot of play on them. I made the right one stronger by moving out the EOS switch, but I'm guessing that's probably not an ideal solution. Have no clue how big the gap really should be on that.
I checked the coil sleeves, coils are fine, not expanded, and the sleeves move freely, so should not be an issue there. Was going to replace them, but the sleeves I have from flipper rebuild are too small diameter wise to fit the rod currently in there? I haven't seen any different diameter coil sleeves anywhere, just different lengths. Not sure what's up with that... :|
How are those links attached at the ends? Never had to replace any of them before, and there's no screw. I've heard people talk about "roll pins" before, but frankly, I've got no clue about that.
