SealClubber
Can a coil be failing/failed and still read 40 ohms? The engine lock saucer eject on my Corvette gets weaker as you play it until it can no longer eject the ball. Only takes a few times. It reads 40 ohms and doesn't feel any hotter than the other coils. The plunger is not binding in the sleeve at all. This is more like a kickback than your typical saucer eject with a cam. Not sure what else it could be if it isn't the coil. The switch which activates it is a normal switch and not an opto and it is working fine. It just starts losing its ooomph to the point it can't lift the ball the 1/2" onto the playfield. Any ideas?
