Wayne Gretzky's 3D Hockey HDD Power
Shou
Roppongi Hills, Tokyo, Japan
I've only dealt with Seattle and Vegas boards where there is an obvious power connector for the hard drive. On this Phoenix board, I see the IDE connectors but no power connector.
Would appreciate some advice as I can't find a manual on the net.
The original HD was the killer instinct 2 Seagate HD, a laptop HD that powers through the connector. You can use a regular HD but will need to tap into your power supply for power.
Err? Hang on a second. The ATA-6 connector used by IDE-era 2.5" drives has four extra pins (after a small gap) for carrying power. It's also a different pin pitch so you can't just cut off the end either. So they're not directly compatible; you need adapters to go between the two.
Shou -- does the "IDE" connector on the board have 20 columns (39 pins, and a key), or 22/23 columns (43 pins, a key, and possibly a gap before the last four pins)? Do you have the cable from the original drive?
Let's get this right and not blow something up.
-E- Correction, I wasn't quite remembering right.
just so you know
the PCB i have is no good
caught fire during testing !
glad i didnt send it to you and turn into huge headache
