Wave runner GP drive board error
GuidoTorpedo
Maryland
So I ended up with this Wave Runner. It is not the big one, but it is about the size of an Arctic Thunder with a regular, non moving seat. Anyway, the game works and plays fine, but on boot up I get an E4 error, and the error stays on the screen. I believe the error is related to not being able to sense the moving seat of the deluxe upright.
How do I do away with this error?
Thanks!
-Mike
I fought with this error for quite a while and more than likely you will find it is related to the steering pot being turned out of its limit. There is a bushing that happ sells that will keep the handlebars from turning too far. They recommend you change it every six months under normal use. You may also have to replace the steering pot as well.
Here is the bushing:
http://www.happcontrols.com/amusement/acesor/50279700.htm
Thanks for the info. I have one doing the same thing. Mine is a Wave Runner GP - no motorized movement at all and the handle bars do not return to center at this time so they are always crooked.
