OU Flight
Trying to get a Golden Tee 2005 up and running. The monitor went out and after trying and trying could't get it to work, so I got another chassis from a member here. Was told it had a convergence issue because the rings were broken on the yoke, but it had been capped and had otherwise good picture. Since I was going to only use the chassis and not the yoke, figured the convergence issue wouldn't be a problem.
Anyway, here is what I have now. Washed out and double image picture. If it hadn't been done already, I would do the cap kit to try to fix it. Is there an area I should focus on here or just do another cap kit?
I also tried swapping the remote board and neck board with the old chassis with no change.
