Was looking if someone had this attachment PCB available
Shawn1976
Donor 10 years: 2016-2025
Saint Augustine, Florida
Was looking to see if someone would happen to have this attachment PCB.
This PCB attachment was used primarily in Dragon Spirit and Pacmania. I think it was also in Galaga 88.
I needed one to service my Galaga 88 and Pacmania if I get a problem with either one in the future.
I don't need any of the wiring just the PCB itself.
If someone has one of these please pm me what you want for it.
Ya I know.
The problem I was looking at was the future.
Due to using a standard jamma harness, I won't be able to go into all of the test screens.
The only one it will allow me to go into was the screen that allows you to change coin amounts, flip screen, difficulty.
I seen listed in the manual that there are a total of around 6 to 7 tests screens I'm assuming that you will only be able to access through the test switch on this board.
Am I correct to say this or no?
All the sound tests and whatnot are accessed using the joystick and button 2 (std jamma btn 2). I ran through all the tests on your board with my regular jamma rig on my bench. Flip the test switch on, joystick and button 2 is all you need.
Ok.
Your mentioning button 2.
Not to sound retarded, but I know to select a change you would move the joystick from left to right.
Your saying that button 2 on Player 1 will jump you to the next screen or Player 2's button 2?
On a standard Jamma it would be player one button 2. That is used to select in the test menu. You move the joystick to get it where you want then hit the button to start the test.
