Wargods Harddrive
Is this the "std res" harddrive? Or is it made only for the med res?
Its both std and med res, just change dipswitch 1 on switch 1 . I changed it and the picture was all blown up large with dipswitch 1 turned on, and it was all tiny and higher res with dip one off.
Hmmmm does the pcb have to be a war gods "kit" pcb to switch to std res as well? Mine is in a dedicated war gods.
I would like to know as well since I am in the same position as you. I have the monitor on my Dedicated War Gods machine switched over to Standard Resolution so I can play MK games and would like to be able to play War Gods without switching the monitor back to Medium Resolution.
I'm pretty sure there is only one Wargods PCB. The harddrive I have is switchable between std and med res.
