Deleted .. waste of time.
I'm going to check that out once I get home tonight. But is it possible to connect these sort of HDD's to a more recent mainboard on my PC? What socket do I use, if possible...?
Dude, your serioulsy getting some strange advice here. (Im surprised at what ive read already)
There are no CF kits for War Gods, you must use the same brand and model number drive as a replacement (Seagate .......)
The harddrive is a laptop style harddrive, so you will need a 44 pin adapter to IDE to be able to connect it to your computer. From what Ive read, your drive is most likely toast. But just to test it, you can connect it to your computer and image it with CHDMAN , but it will probably just crash.
Your best bet is to look on ebay for another laptop drive that is the same model and part number. Then use CHDMAN to image the drive with the wargods chd file.
