mrbill2084
In case you did not know, when you write >$200, your saying you want to spend more than $200...
As cadillacman already knows, I have the same model iron as he does. Mine has worked well so for and I also had to replace the iron before the first tip even wore out. I got about 2 years of hobbyist use out of it before that happened. Overall I'm happy with it. It would be nice to be able to change out the heating element of the iron, but at least the replacement iron is only 8 bucks or so. I did see a lot of negative reviews of the iron on MCM's website, but I don't know if the 2 years I got out of it is considered good even for a lower end station. I don't do enough soldering to justify spending a ton on a Pace setup.i bought one of these when it first came out, along with a spare iron and a selection of tips.
http://www.mcmelectronics.com/product/21-1590&CAWELAID=445475968 ( different face plate but same thing)
I literally wore the iron out before the tip went bad, so im on iron 2 and still going strong. That first iron went thoguh hell man. Have not touched my spare tips, and i dont think ill need to.
It was money wel spent in my book( periodically this goes on sale for $60, $70, $80 if you find the promo code)
Hahaha - that's because the ENTIRE WORLD with the exception of the USA uses Centigrade....better get used to it as well as metric as China takes over..…..
Do you really need an adjustable iron? I've always just used a generic plug and play iron, it gets hot enough to melt large connections and for the small ones I just get in and get out quickly-never had any problems.
Most definitely. Some boards have weaker traces than others so setting a heat ceiling is a good thing.
I also have the Hakko 936 and highly recommend it. I even like their Hakko 808 desoldering gun and am always tempted to buy one every time I walk into Fry's. lol
another reason i got it is i do a lot of automotive wiring and it's just easier to get into tight spaces.
OUCH
I just got a vision of a blob of hot solder dropping into my eye while trying to work underneath the car...
I bought one of these about a year ago: http://cgi.ebay.com/Solder-Station-...098?pt=LH_DefaultDomain_0&hash=item563e976ab2
I only have 2 complaints about it:
(1) a red LED power on lamp would be nice. You need to look at the LCD screen to see if it is still on. I left it on overnight oncebecause I didn't look at the screen closely enough
(2) The power cord should go out the back so the iron stand could go on either side (it is freestanding, but on my bench it is more convenient on the left which is where the powercord comes out).
Neither of these is really that significant. It works great, heats up very quickly and holds the temp extremely well. I don't really know how I lived with RadioSh*t soldering irons before I got this one.
Don't let the low cost fool you, this is an industrial strength soldering station. I use it for cap kits and board work all the time.
ken
In a previous thread, someone said they were compatible with one of the major brands. I think I got 10 when I bought it and so far I'm still using the original "pencil" tip with no signs of wear on it. So I am not worried about replacements.
I have gone through a brand new 1 lb spool of solder and about another 1/4 lb of a previous spool since I got it. So it does get a pretty good workout.
ken
The intelligent LF2000 provides an "Easy to Read" digital temperature indicator, a detachable 90W solder wand complete with tip, and a "Set and Forget" temperature control that allows a precision accuracy "On Demand" heat setting range of between 200°C and 450°C (392°F to 842°F ). The power unit is isolated from the A.C. line by a high quality transformer and only 32 VAC voltage is used to drive the heating element. The tough plastic PC housing is stronger to better withstand high impact bumps and abrasions. All materials meet UL standards.
The Intelligent LF2000 exceeds all soldering equipment military specifications regarding electro static sensitive devices for critical applications where unwanted static discharges may damage components. When soldering is suspended for 20 minutes, the soldering iron will go into a sleep mode with a temperature of 200°C. After 40 minutes of sleep without Wake-Up, the heater will power off to save energy, protecting the soldering tip and guaranteeing safety.
Precision "Tip Temperature" Accuracy is mastered to within ±3°C(6°F) utilizing state of the art circuit technology and a built in P.T.C. sensor, located at the end of each ceramic heater shaft for accurate temperature control. The ceramic heater has the advantages of high power, long work life, fast temperature recovery and fast temperature compensating, which is more advantageous for lead free soldering.
The wand features an ergonomic mini handle that stays cool. The handle assembly cord is made from silicone rubber that won't be damaged when coming into contact with high temperature irons. The soldering temperature can be locked by a password and is convenient for production management.
Hey guys, I'm gonna have about 7-9 soldering/desoldering units up for sale in the next couple of weeks. mostly PACE, 1 Dennon Instruments Corp. (DIC) SC-7000Z desoldering gun (the industrial version of the HAKKO 808) A few SMD rework iron attachments (for the PACE units) a couple of temp controlled Weller stations and 1 maybe 2 METCAL PS-800s (my FAVE) .
Check the for sale section in a couple of weeks. They are all used units but in great working order. No prices yet, still gathering stuff for the sale.
Anyone have the Hakko FX888? It seem that this is the replacement for the Hakko 936. Does either have a ready light? or is that light on the front just to let you know it's on?
Mine just arrived from Fed Ex yesterday. I'll be firing it up this weekend. I read over the manual and it says the light will blink/flash when the set temperature is reached.
I can't wait to try it out. It looks great and feels "quality".![]()
the hakko 936 http://www.google.com/products/cata...=X&ei=0CZ1TZL5GZDWtQPpgojcCw&ved=0CEgQ8wIwAg#
Best iron i have ever used heats fast and recovers fast
