Wanted Williams back upper door bracket
dahnz
na, New Zealand
I'm looking for the interior metal bracket that the lock on the upper back door of a Williams cab rotates into (see pic). It's for my Stargate, but I think they're probably all the same. I'm sure I've seen them for sale somewhere, so if anyone knows where, that would be very helpful.
Thanks, Dominic
I gave up finding them a couple of cabs ago. If you go to HD or Lowes you can buy a piece of 3/4" angle iron and cut a piece about 3-4" long and mount it on the top of the cabinet at the right distance and it will work for locking the back door. It won't stop a crowbar, but then neither would the original lock plate.
You'll have to measure to get the distance right. I found the easiet thing is to remove the monitor and bezel and have someone hold the door in and turn the key while you go in through the front to measure where the lock cam is. If you angle it slightly you will get that "pulling the door tight" effect as the cam slides along the angle iron.
ken
