[Wanted] Taito Power Supply (working)
the title almost says it all, except that it should work in a jungle king / hunt!
if you have one for sale, please drop me message ...
Superully said:[Wanted] Taito Power Supply (working)
well, right now i don't have any power supply at all in my cab, BUT the original wiring harness. i could hack up the harness and attach it to a switcher, but i don't want to do that. i'd rather put an original power supply at the bottom of my cab and splice in the arcadeshop switcher. does this make sense?
You don't need the PS board (closest to the back door in your pic) if your going to put a switcher in there, and you dont need the heat sink, black thingy either.
Superully said:so you're saying this is what i need (at the bottom of the cab):
I will take a picture later today for you to show you what I did to my Elevator Action. I got rid of all the original Taito stuff and started from scratch. It took about 30lbs off of the weight of the cabinet.
this is what's left of the wiring / interior in my zoo keeper cabinet, but since i will be getting all the parts needed (including a power supply with an isolation transformer and a complete wiring harness), i might as well remove this from the zoo keeper cabinet, put it into my jungle king cab and get the switcher from arcadeshop, right? that should do the trick then ...
hey joe, are you drawing that picture by hand?would be cool if you could enlighten us with your setup. thx a lot for your efforts already!
join the connectors as we discussed, you will end up with an extra purple and an extra white/brown striped wire that are not used in this game.. (guess this harness runs other Taito games)
then connect the remaining V1 connector wires to your Universal switcher.
I can take all the pictures you may need of my setup.. it works and it works well. I have been told by many the original PS was garbage from day one... So you are not hacking the game, you are UPGRADING it..
