wanted street fighter II control panel
That looks like a Data East cabinet, perhaps Karnov? Similar to a Dynamo, but different in the control panel area.
that looks right. I believe it is a dynamo cabinet. They also had cut corner panels that went with that style of cabinet or close enough were they look almost alike.
What is wrong with that panel? new overlay and good to go ?
The cabinet profile is different between the Data East cabinet and the Dynamo cabinet in the control panel area. The Data East is pointy where the Dynamo cabinet is more boxy. I don't think the control panels are interchangeable. I can't attach pictures at the moment, but they are different.
Im thinking it's not a Dynamo, never seen one with the sides sticking out past the front like a Robotron, also the contour around the CP doesn't look right. Leaning towards the Data East.
That is a Data East Cab.
Look at Commando, Kung Fu, Karnov, Bad Dudes, & Robo Cop.
If you look closer, you can see the black paint hinting over a Kung Fu patterns on the bottom CP.
Dynamos has a3" vertical front before it curves back into the kick panel.
Insane they drilled all them holes to fit on that CP.
data east cab. I am pretty sure you can use the hs1 panel. I have both here and can confirm if no one already has. but I cant check for a few days as its going to rain.
