Wanted: Scan or Pic of Captain America CPO
First hit on google...
this is the only piece I'm missing for a full conversion of a Konami cab to Cap America...
I wish someone repro'd it.
Even without a scan you could make an incorrect reproduction that no one would notice in 10 years unless it was pointed out.
It is essentially 4 stock marvel characters, Cap's shield, a Data east logo and a really simple background.
If you are going to use the IL or HAPP joys on that Paradise sells a replacement shaft that will take ball tops. I would use a white ball top on Vision, Purple on Hawkeye, Red or Yellow on Iron Man, and Blue on Capt.
The shaft is hollow so if you wanted you could use the LED lighted balltops
http://www.paradisearcadeshop.com/e...ck-stainless-steel-hollow-joystick-shaft.html
Here are the slip rings
http://www.paradisearcadeshop.com/en/joysticks-trackball/376-ultimate-arcade-slip-ring.html
I can't find the leds for the ball tops, ask Bryan.
One other thing, I assume Vision uses the 1 player controls, Ironman uses 2 player, CA uses 3 and Hawkeye uses 4? I want to have the 1 and 2 player controls be front and center when I wanna switch jamma PCB's. Does that mean I'd have to move Vision to the 2nd stick, Ironman to the third, CA to the 1st and Hawkeye to the 4th?
I will ask my friend who has the board set.
Maybe I'm confused, but you choose your character when you coin up...
It's cool, but I definitely prefer the 80's art...
If I could find good vector files or high res images of the 80's style art I would go with it. I have just learned that trying to get a scan of the original artwork from anyone on this forum is usually a dead end street.
I'm sure if you look hard enough, you can find art that would work. You'll have the toughest time finding the white Vision, mostly because he's stupid-looking that way. Maybe the green/yellow/red Vision could be used on the cp?
For sure. His stick and buttons will be yellow so that version of the vision would work out better.
If I had a decent overhead shot of the CPO and the correct dimensions, I could rework the artwork the way you want it. I might just be able to with the first pic of the tread. I'm not sure I could get the over all perspective correct with that pic but, I could give it a shot.
Since it is a conversion and for your 3-year-old why not have fun and use Marvel Super Hero squad art on the cab? The only character you might have a hard time finding in that style would be vision.
Not when the dips are set for the 4 player version. Each player has it's own coin and start button.
yes and no, there is a dip for 2 and 4 player control panels, and there is a dip for 2 and 4 coin slots, the 4 coin slot option accepts coins for each character accordingly, adding life to the character you inserted the credit to. however the 2 coin slot option lets you choose what character you want to play with or adds credits and you press start on the character you want the extra life for weather the 2 or 4 player option is selected on the dips.
btw I am also looking for a high res scan of the 4 player CPO if anyone knows where to grab the file would be much appreciated,
thanks,
sirelboe
check out my custom cap america cpo
skull =
plain =
