Wanted: Repair or replacement WG chasis
sjfreddy
New Jersey
I have a Wells-Gardner #19k4601. The tube has no burn. Does anybody repair these chasis or have one for sale ? Right now the monitor just has a horizontal line going across it. thanx fred
most likely an issue on one of the daughter cards. Pull them, check for cracked solder connections, reflow as necessary then reinstall.
chris25810 might have some comolete chassis fs.
also chad at www.arcadecup.com will rebuild your chassis
id offer to work on it but i have not had a ton of experience on those 4600s.. if you had a k7000 youd be in luck
If you wanna send it my way, i can get it fixed for you with some fresh caps and alot of solder re-flowing. I have a couple in the cabinet just in case but i don't see an issue with fixing yours and keeping your chassis/tube mated.
