Found or No Longer Wanted Wanted: Q*Bert harness
I've got a complete uncut AC harness out of a Krull, along with all the yellow grounding straps. So half of what you need. Ping me if you end up piecing this together, and need the AC side. I also have a working Gottleib power brick.
This is what I'm dealing with inside this Q*Bert cabinet.
Looks like at least part of the power harnessing is here. Most of it is gone and/or hacked up into Jamma Hell.
I feel for you. I found the same type of butchery in my Krull. I ended up doing a full rewire and put a JROK in it. Good luck finding all the bits.
In this case the only things stopping me from going the JROK route are:
  • I have a complete boardset (cpu, sound, linear psu)
  • All my other machines run original hardware, so I'd love for this one to also.
Because it's already jammafied, I could just drop one in at any time if I wanted.
I respect that. In my case, all I had was the power brick and the AC harness, and too much money into the cab to justify hunting down a power supply, boardset, harness, etc. Plus I really wanted to play some Mad Planets and Qbert on the machine. I have a really nice marquee and bezel here that look to be high quality Phoenix repros, if you need either of those let me know. I think @dj dns sold all his Qbert stuff earlier this year, but he was sitting on a ton of it and would be worth talking to.
There are two harnesses types that I have run across in my travels. One with the filter board and one without. By your picture i suspect it the one with the filter board..
Maybe a reproduction will work..
Yup. Aware of the Repro harnesses (which are amazing work by the way).
I'm probably gonna hold out for an original of either variety (filter or no filter) for a little while before I spring for one of those.
