Looking for two Pole Position EMI filter boards.
Thanks,
-Charles
Thanks,
-Charles
I have this one....double-check to see if it's the one you are looking for.Looking for two Pole Position EMI filter boards.
Thanks,
-Charles
This is what he's looking forThat is not the correct filter board for pole position. Pole position is a two board stack so the connectors are offset. That filter board is for a single pcb with both connectors.
Thanks. I wasn't certain which is why I included the part# pic that is right on the filter pcb.That is not the correct filter board for pole position. Pole position is a two board stack so the connectors are offset. That filter board is for a single pcb with both connectors.
