WANTED: Playchoice gun holster + Coin door
TraderSteve
Mountain Top, Pennsylvania
I have a single monitor PC10 that needs a coin door and a gun holster. I've only seen 1 coin door on ebay for $30 and it has a bit of rust on it so I've been passing on it. Attached are pics of the unit so you can get a feel for what I'm looking for.
If nobody has a PC10 gun holster available, can you send suggestion on what you used or what I could use so the gun is no longer sitting in a bucket on the floor.
Also if anyone could help I seem to have a "calibration issue" with the gun itself. I can hit the ducks in duck hunt from anywhere (right on the glass or 3 feet away) but can almost never hit the Discs... It seems the sight at the top of the gun isn't quite helpful, but if I aim to the right and down from it, I can hit any time. I'm assuming the discs are more problematic just because they are smaller, any advice on how you can calibrate the sights ?
Any help / suggestions would be appreciated...
Thanks!
---S.
EDIT: Can an Admin change the thread title to: "WANTED: Playchoice gun holster + Coin door" ?
I hit post too fast and can't edit the title.
Thanks!
---S.
The gun hit/miss issue is likely due to the brightness level of your monitor. Try adjusting the brightness while someone plays the game to see if you can find the sweet spot. It could, also, be a problem if your monitor has heavy burn-in.
I was thinking it could of be burn in (though I never see it) because there are parts of the screen that I just couldn't hit, then I stood on a stool to change my angle (shooting down at the screen now) and it works MUCH more accurately.
Does that make sense? Could it just be that my monitor is mounted at the wrong angle ?
Did you try adjusting the brightness while someone is testing the gun?
Not yet (at the same time anyway). The Wife went to sleep early last night and I was hoping she could help after my 4 year old went to sleep but she was exhausted.
I will be sure to try it though before I consider unmounting the whole monitor and resetting it. Not in a hurry to do that.
If the brightness adjustment doesn't work, then trying removing the "smoked" glass bezel and see if it works. I had to change one of my bezels from smoked to clear glass, so the gun would work properly.
