WANTED: Nintendo Joystick knobs and collars
JamBurglar
Virginia
I need two knobs, two knob collars (TMAU 12-16), and two knob plates (TMAU 12-14) for the Mario Bros (Vs./DK3/Playchoice/Punchout) style joysticks that go with metal control panels.
I actually do have the shafts, but someone managed to remove the knobs and the collars from them (I've never been sucessfull at removing the knobs from the shafts myself.) If you have the knobs with the shafts (TMAU 11-18) I'd take that too.
I already have the rest of the joysticks. I figure I could easily replace the whole joystick assembly but I thought it would be better if someone had just the knobs, collars, and plates, then I could save a few joysticks.
Thanks.
Might have a piece or two
When I go out to the shop I will take a look.
I should have the washer and maybe a whole shaft. I remember buying a replacement somewhere, but not sure if it is the same as the one you need.
Michael
Forgot
I meant to mention - I had bought a new Joy for a DK just to see what it looked and felt like. The Shaft came with the new sleeve, like the ones you seek. It appeared to be just a piece of clear tubing which could be had at Lowes or Home depot in the plumbing area. Mine was cut crooked as well. What a bummer...
