Walmount - Rowe v nsm?
Boo32
Richmond, Virginia
I have seen a number of posts about the reliability of rowe wall mount jukeboxes. How do the nsm machines compare? It looks like parts are equally available.
nsm vs rowe
well it dependse who you ask there both very good boxes I have owned a couple hunred of each as far as cd boxes go the rowe's sound better but both work well the es-v used in emerald ice,digital thunder,preformer 2000, wall boxes are the best as for the best floor nsm boxes go digital thunder,pfreformer 2000, I like the best the title drums people say give them fits i couldnt disagree more there easy just keep the worm gear lubbed 1x a yr and make sure the plastic pieces are tucked in when you change music and they will run for years the only thing i could say was bad about nsm is the ardac bill acceptors and the reason is the control box is mounted in a place where it has no air flow and it gets hot and never works correct thats why you just convert it to a mars and be done with it i hope this helps
gary
As service and dependability goes, Rowe is the machine.
