Wacko Noise
flynn54321
GREEN BAY, Wisconsin
Having a problem with my Wacko... put the machine in test to see if I could figure it out... went to the channel test - all 6 tones are there - however i will try to describe what its doing.
All the tones are there - but the best way to put it - is it sounds like a radio that isnt quite on the station.. like the dial needs to be moved just a little bit for it to come in clearly.
There is a little static on each tone... this interferes with some of the game play sounds..
I tried a different dual sound amp and nothing changed... anyone have any other thoughts?
yeah my experience with these games (which may not be relevant to your issue) is the connector to the middle board (9 or 10 pin I think) with the uncoated wire tends to get finicky. try wiggling it , pushing on the wires, etc. while the game is on and see if you hear any changes.
