Ok, you asked for it. FYI - this is a listing of the actual original caps found on a 27" D9202. I have done two D9200 chassis' with this listing. Not sure if they were both D9202's. About 6 of the caps are different values than what is seen on the schematic found on WG's support site, but they are original and I replaced them with what was there, and the chassis worked. If you have a different model or size (33"), then you may have some values different.
Here ya go:
Neckboard
C215 - 100uF 16v
C223 - 22uF 50v
C224 - 100uF 16v
C227 - 100uF 16v
C229 - 100uF 16v
C230 - 100uF 16v
C231 - 10uF 250v
C232 - 33uF 250v
C235 - 100uF 16v
C240 - 100uF 16v
C246 - 10uF 250v
C250 - 10uF 50v
Sync Board (small vertical board soldered to the main chassis)
CH03 - 22uF 50v
CH05 - 22uF 50v
Main Chassis
C101 - 100uF 16v
C102 - 100uF 16v
C103 - 100uF 16v
C104 - 47uF 16v
C104 - 47uF 16v
C110 - 100uF 16v
C111 - 1uF 50v
C112 - 1uF 50v
C113 - 1uF 50v
C114 - 100uF 16v
C115 - 1uF 50v
C116 - 1uF 50v
C117 - 1uF 50v
C118 - 1uF 50v
C121 - 10uF 50v
C306 - 2200uF 25v
C308 - 220uF 50v
C314 - 2200uF 16v
C317 - 1uF 50v
C318 - 2.2uF 50v
C324 - 1uF 50v
C329 - 100uF 16v
C401 - 10uF 50v (BP)
C402 - 4.7uF 50v
C407 - 100uF 16v
C409 - 1uF 50v
C411 - 47uF 50v
C414 - 220uF 16v
C415 - 1000uF 16v
C417 - 22uF 250v
C418 - 47uF 50v
C422 - 22uF 50v
C423 - 4.7uF 400v
C425 - 47uF 25v
C433 - 100uF 16v
C445 - 47uF 50v
C447 - 10uF 250v
C451 - 10uF 250v
C452 - 47uF 50v
C458 - 47uF 50v
C466 - 470uF 25v
C472 - 10uF 50v
C806 - 33uF 25v
C807 - 470uF 250v (Filter)
C808 - 470uF 250v (Filter)
C810 - 100uF 25v
C813 - 10uF 50v
C814 - 10uF 50v
C820 - 10uF 50v
C823 - 470uF 25v
C825 - 220uF 200v
C826 - 100uF 200v
C827 - 470uF 50v
C828 - 2200uF 16v
C832 - 100uF 16v
C834 - 100uF 16v
C838 - 220uF 16v
C839 - 10uF 250v
C844 - 4.7uF 400v
C847 - 470uF 25v
C901 - 10uF 50v
C904 - 47uF 50v
C905 - 10uF 50v
C907 - 100uF 25v
