Vs Unisystem and Popeye compatibility?
TheDrewster
Donor 2012
Reno, Nevada
So I bought 2 games tonight, one of them being a Vs. Excitebike in a Popeye cab. Does the Vs system use the same wiring as Popeye? Sure looks similar, but then again, those could be famous last words.
I think Popeye uses a different power supply.
Power supply is fine, check QuarterArcade for a full Popeye harness. The 2 harnesses (other than the 22/44 connector) are nowhere near the same. Popeye uses only that one edge connector, Vs. System uses 2, the 22/44 and a 15/30.
