Vs. Super Mario Bros conversion to D2K question
dethfactor
Donor 3 years: 2011, 2013, 2021
Portage, Indiana
Picked a fairly decent vs. cab and I want to convert it to a d2k. Outside of the dk pcb, d2k z80 mod and a cp, is there anything else that I need/may not work?
Vertical monitor mount hardware, monitor shroud, wiring harness, you'll need a 4-way joystick if you by an unpopulated CP.
Get a harness adapter for Vs. to DK, and you'll save yourself a lot of time.... it'll use the existing CP just fine.
Will I need a complete DK harness for this? The VS has an EZ20 mounted horizontally, so I would need to mount it vertically. It has 2 4-way joysticks and 4 player buttons and 2 start buttons. Thanks for the info.
I actually don't think I want to use the existing CP. I have a 2 player CP and I want to use the CPO included in the D2K art kit which is a 1 player cp. Thanks for the info though.
