vs rbi baseball
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
I have all my board for my red tent, and I want to play some rbi baseball.
anyway, the colors come up light blue and something else. I don't know what the proper colors are, but these seems wrong.
I expect green for the grass and all, right?
I have the proper ppu, and tried another proper ppu to play it safe. I reseated the rom chips. I couldn't get the daughter card loose (afraid to pry it off too hard I guess)
what's the next move?
Have you tried other games and are geting the right colors?
The PPU you should have for RBI baseball is an 0001 PPU...
The daughter cards are hard to get in and out and need some good force, but the force has to be even so that you don't bend the pins. I would try re-seating the card.
Did you try adjusting the RGB knobs?
I didn't do anything aside from changing out the ppu.
And yes, I do get normal colors when I have other games in there.
On another side note, how do you adjust volume?
There is a volume knob with the other adjustments right below the monitor.
The 2nd one from the left offhand???
The volume adjustment is one of these:
attachment.php
Any numbers on the PPU?
yeah I have the proper ppu, and I pulled both ppu's from vs baseball(which appear to be interchangeable) and same thing.
Does anyone have a link to a screen shot of vs baseball? Maybe the pastels are the right color.
ok, I pulled it up on youtube.
My colors are whacked. I suppose I could pull the daughtercard and try it on another board to see if it's that half of the main board with problems huh?
ok, so I decided to mess around and I pulled a ppu from the tennis board I have.
It's a RC2C03B .......
now it's golden, game works perfectly, colors are great, game play is great (it was before though too)
what gives?
is it possible it has something to do with the dipswitches on the daughter card?
For the record, in case this thread helps anyone in the future.
I had to adjust the dip switches 6-8 and the color was correct with the correct PPU.
