Those were the measurements I used, and it did fit in the back of my Honda minivan. Only word of caution when moving these, other than the size, is that you can't access the coinbox if you do not have keys to the coin door. If you do not have access to it prior to moving, you might want to drill out the lock and make sure you don't have coins in there before moving.
Measurements for vans aren't an issue. Make sure you can get it depth-wise through your door at your destination. A lot of people have problems on that one and end up removing the control panel base as a last resort.
