Vs. Dr. Mario stopped working after 30 min!?
doesbenfoldfive
Richmond, Virginia
Just bought this from a klov'r and played it for 20 minutes last night. As I was, the screen would stretch/zoom slightly then go back to normal. Figured it was nothing.
Started playing this morning. 10 minutes in the screen went black. The music/game kept going for another minute or so then cut out.
Now when I flip the switch on the back, only the marquee turns on.
I checked the fuse by the switch and the one on the back right (looking from the back) of the monitor. Both are still intact.
What happened?!
It's this cab.
http://forums.arcade-museum.com/showthread.php?t=240993
Was told it was converted from a Donkey Kong. There are extra wires/connectors inside.
I switched the marquee plug and the monitor plug to see if the jack was messed up. The marquee works in either plug. So I guess that is OK...
I don't understand why nothing cuts on now after both things stopped at slightly different times.
Stupid question: How do I check that? I have a multimeter. Do I leave them in or take them out? What should they show? Which setting do I leave the meter on?
Verify that the power supply is actually getting power. I find it difficult to believe that both the power supply and monitor stopped working within minutes of each other, there must be a problem elsewhere.
Took everything out. All the stuff tested fine. It's not blowing fuses.
Put it back in, still no video/audio. Just the marquee.
Help!!! I'm at a loss.
