Vs. Cab wiring question
AlkalineJay
Donor 2013
Oak Ridge, Tennessee
Alright, so I've got a Vs. cab that will either be turned into a mario bros cab, or a donkey kong. Is the vs wiring harness and/or pcb cage wiring compatible with either of these games? If not, what needs changed? Thanks! -Jason
Your going to need the game specific pcb,control panel & wire harness for any of the ninty classics,you can use the cage but not the fcc panel but you don't need to use a fcc panel anyway.
Hope this helps
You will to need change everything but the coin door, power supply and the monitor. DK & DKJR do not use the cage, Popeye, Mario Bros and DK3 do.
Hahaha, I'm well aware I need the pcb, Im mostly curious about the wiring. Ive got a vs cab with the cage, but it was clearly originally a DK style cab. Im wanting to turn that one into a Mario Bros, and wasnt sure if the conversion kit was designed with minimum change in mind for the op. Thanks for your info phet!
Wiring was covered under the umbrella:
"You will to need change everything but the coin door, power supply and the monitor. "
Gotcha, now the fun part...tracking down the proper wiring...
Just ask Dokert if he'll make you one. You might find one, but in my 6 years of searching Ninty parts, they seem hard to come by. The easiest harnesses to find are for the Vs. system and for Popeye. A Popeye harness would work with some modifications.
