Vision Pro's picture shakes in Root Beer Tapper.
Jeff F
Donor 12 years: 2011-2022
Johnson City, New York
Here's a new one to me... moved a newer Vision Pro monitor from our Crazy Climber to our Root Beer Tapper. In the Crazy Climber the picture is 100% stable. In the Root Beer Tapper it has the shakes.
After fooling around with the sync signals for 30 minutes, I took the monitor back out and put it back in the CC and it worked fine.
So then I moved it back to the backside of the RBT and connected it outside the cabinet and it shakes.
So then I put another monitor into the RBT and the picture is 100% stable.
You probably can see where this is going... no matter what I do, I can't figure out how to stop the shakes on the Vision Pro monitor when it has the RBT signal on it.
Any ideas?
Double BoooooooO! (I knew what you were referring too... I was just expressing my opinion on the almost joke) ;)
Ugh. Thanks for the info.
Curious if any of the extremely smart people have looked into why? There has to be something a little different about the signal.
More likely that the new-fangled modern sync processing circuit of the monitor can't handle it. I see this most often on "sync-sensing" monitors...
