78whiteorbs
Got some background interference from a vision pro monitor that I have tried in two completely different cabs and with different tubes . Other monitors work fine in the same monitors with the same power supply including another vision pro monitor.
Picture is beautiful otherwise. Thought maybe it was the uso Trans as I know you don't have to use one with this model.
Or read it could be a ground issue .
Important to mention I can hear some excessive voltage crackle/chatter in the tube that my other vision pro chassis doesn't make with the same tube. Problem seems to be following the chassis, but beside the the picture is newr perfect and fresh.
