Vision Pro 2 or WG7000
Wg is going to have better customer support via email and may still stock some the dwindling supply of crt chassis parts... support on the vision pro will likely be nil.
7700 likely has a better electron gun set vs. the vp... the vp has problems however is simpler to fix vs. the more complex d7700... the tubes don't last long on the vp before they are in need of rejuiv.. However if home use, you're not going to be having your game on 24 seven unless you need your games to put you to sleep leaving one on in your bedroom
You can buy the VP2 for $199 or the Kortek for $189 from Arcadeshop. I'd go with the VP2 myself.
Happ no longer carries a 19" cga crt...
