Vision Pro 19" interference
drewbo81
Donor 2017
Greenfield, Wisconsin
I have an upright sega turbo and I know there is supposed to be a 100v sega monitor inthere but the one I have is dead. Anyways Ive installed a vision pro 19" crt and am getting picture but lots of wavy interference. Ive tried with iso power and also without iso power plugged directly into wall. Ive also disconnected fan with no luck.I continue to get interference. Any help is very much appreciated. Also when plugged into wall and game gets turned off the monitor continues to hummm. Any thoughts?...
I just had one of these doing the same thing. I recapped it and now it's fine. The original caps on these are pretty crappy.
Also try removing the ground on the frame if you have one attached. I've had that cause similar issues with a vision pro
